You guys were so much help with my 93 GTS that I thought I would try again and see if you can help with my second ski.
Have owned this one since 2007 and it has always had some issues starting. Our mechanic told us if he put a primer on it and removed the choke that we would have no more problems. This has been a source of major frustration and it was harder to start than before.
I went out to prime the carb (5-10) pulls, and then tried starting the ski with no success. The engine turns over just fine. The plugs are both sparking. All of my fuses are fine. I pulled off the fuel filter under the front compartment and only had a minimal amount of fuel come out. In the bottom of the filter housing was some gray substance that felt kind of clay like.
I then noticed the lines that the mechanic hooked up to the primer and could not see any fuel in these lines. Could my fuel filter in the tank be clogged not letting any fuel out of the tank? I don't want to pull the tank if I don't have to and am looking for any suggestions that might point me in the right direction.
Thanks,
DC
Thanks,
DC
