98 GTXL MAG fouling problems
HappyMongo
Hi all, need alittle help again and hope you's can assist as am lost, after a engine rebuild i am running pre mix @ 40:1 seadoo oil, the problem im having is the mag is fouling the plug after 20 -30 mins in the water, i have taken the carbs apart cleaned rebuilt and set low screws to 1 1/4 and high screws to 0 set the pin arm, it smokes when at high revs out the water but runs ok, response is great throm idle to wot but as soon as you pull a ringo or have two peopkle on the ski it fouls the plug again?:rofl: the only problem i have is one of the bellows on the RAVE valve is split and im waiting for a replacement and its on that cylinder and it leeking oil from the weap hole, i am woundring if this could cause the rich condition?( at least i think thats what it is running rich) or is there something im missing, have replaced fuel lines, cleaned selector and replaced fuel filter, Sorry link so long but i've been reading loads of links and still have problem, at my wits end honestly, would love some help/advice,
Thanks people
p.s compresion test showed 120 in both cylinders
so after looking around on this website (which is great), i think the RAVE could be a cause?
Any ideas anyone? Please:ack:
Steve
