CdnSeadooer
Good day all, I have a 1998 Limited, 951 dual carb and I have a few issues I need help with.
1. When I bought my seadoo in 2015 everything worked except the speedometer. I now have a 12v low alert that beeps every 20 seconds and is very loud and annoying. My gas gauge also stopped working however my multi function gauge works just fine. I do not care about the gauges working but I would love to get rid of that beeping. The seadoo fires up first try, runs perfect and has a new battery. After a weekend of on and off use (and multiple starts) I pulled and tested the battery and it was at 100% charge. I am not certain why its giving me a 12v alert warning if the charging system is working properly.
2. When I run the seadoo with a water hose on the trailer my RPMs spike as though the water is not attached. I am afraid to do work on the seadoo outside of the lake because after 5 seconds of running my RPMs shoot up to 4-5000K. In addition, I heard the idle rpm should be 700rpm, I have played with the carb adjuster and the seadoo runs better under load when the idle is closer to 900rpm. Any thoughts?
3. When I pulled my plugs last fall one was clean and other a little more black. Is it normal for one to be a little darker or do I have a carb issue?
4. I'm replacing all my grey tempo lines next week. Any tips would be appreciated.
