Venturian1
A little reluctant to start when cold, idles fine, revvs up when out of the water, runs ok at 1/4 throttle, but towards the top, it hesitates. I found that pulling the choke out a little it takes off and winds out nice. But I would rather keep both hands on the grips.
This carb has an accelerator pump, and I tested the diaphragm and check valves, and the restricting orifice on the input side that's in the small fuel hose.
Pop-off pressure within 35-42psi, fuel pump check valves both holding, correct jets and needle & seat is 1.5, and the arm is level with the bottom. could the lack of fuel be caused by not enough restriction in the return fuel line? I opened the high speed mix screw 1/8 turn it got worse. I put a hose pincher on the input side of the acc pump, it barely ran. I removed the tiny restricting orifice, no difference. Base gasket new, fuel hoses all new, screen in carb clean.
I know Y'all are smart. Any Ideas?
Oh, I lowered pop-off pressure to 25 - 30psi which improved it by raising the point at where it starts hesitating (crapping out), a little.
