rksnow1
Hey guys, I put my 98 GTS w/ 717 in the water for the first time this season and noticed that the "tell tail" was not pissing any water in the back. I got the ski late last season and dont remember if it worked then.. It seemed to be running fine and not over heating but I only had it out for a quick first test run..
When I got home I blew all the lines out with air and found no blockages. Put it back on the hose to test and still no "tell tail"... Im thinking the water lines are mixed up. I've looked at the parts fiche diagrams and read through a few hundred posts last night and still am not sure.
This may be hard to describe so Ill try and attach a pic. One the top rear of the engine there are two water hoses and directional markings stamped on the engine cover.. The hose on the right has the cleanout attachment but is attached to the "out" arrow? is this seem right? Wouldnt the water want to circulate through the engine. The other end of this hose goes to the white opening through the hull, top right of the jet nozzle
If this all seems correct, any thoughts to why the "tell tail" is not working? What should I check next?
Thanks
Thanks
