rickytx1981
Ok, have a 97 seadoo xp that was driving fine all last summer and the begining of this summer. I felt a little cavitation so i took the pump off and had a new wear ring put in and the impeller checked, So now here's where the problem come in. when i took the pump off i realized that i had some how pulled the drive shaft out i tried to put it back in and it wouldn't go in enough so i looked and saw that the coupler had fallen off well put it back on and went to the lake and it started good but wouldn't move just reved looked and saw that the drive shaft wasn't spinning so took it out of the water. well i realized that i had put some things on wrong so i fixed it by looking at the manual. ok now i have everything back together and i started it up but the impeller in not moving (does it need water for the impeller to move?) and , the drive shaft i can spin the drive shaft with my hand when not started, does this sound normal? i don't really know about pwc so i'm hoping someone could help. I;ve been searching this forums and have seen not post like mine and thanks in advance for your replies
