i just recently bought this 97 xp and has been running great to recently. motor falls on its face at wot and has to be be babyed up to full throttle,( if itll actually get going that fast). Checked plugs and the back cylinder spark plug had micro metal flakes on it. I at that moment removed it from that lake and is sitting in my garage.
Ive done a compression check it both cylinders are at 100 psi.(ive heard that there's 2 different readings you can get from a cold engine and a warm engine. what one would i have to do for a proper reading?)
when it was running for the short last minutes it kinda sounded like it was not getting enough oil to lubricate the engine properly. im going to remove the oil pump shaft and put it back together but dono if that has anything to do with it.
im new to all this fun stuff so might be asking dumb questions but hell gotta learn sooner or later!!
any help would be GREAT thanks
