sportsfreak90
I bought a 1997 SPX a couple weeks ago and finally got the chance to take it out for a test drive today. Got rid of the old gas, put new gas in (highest octane obviously), put brand new spark plugs, lubed everything up so everything moved smoothly. Fuel filter isn't bad, cleaned it after the ride but it wasn't all plugged up or anything.
Started the jet ski on the trailer for about 10 minutes in the water, revving it up and everything seemed fine. Pushed it off the trailer and took it out and about two to three minutes later I was having bogging issues. It felt like it was being starved of fuel but it wouldn't die on me. I'd leave it at a low RPM for about five to ten seconds and it'd run fine again, over and over again. Brought it back in, ran it up on the trailer and let it idle a bit longer. Idled fine, revved it up and it did fine.
Any thoughts on what could be wrong? It ran fine for the first bit, idle on all the way up to full throttle, and then after a full throttle pass, it started bogging. Wondering if maybe the full throttle pass pushed something through the carbs and it is possibly choking on them?
I pulled the RAVE valves out and they are pretty oily and dirty. I'm going to start with cleaning them and putting a new gasket on and taking it back out again and seeing how it runs. Any help would be appreciated. Thanks!
