That Amazon is junk, aftermarket.
What exact part number did you order from osd, it will be on your order. OSD1XXX?
Well I am still here and cheering for ya!
You are at point now that you should feel very very solid and confident on the function of the fuel system, right?
Mu experiences are that After going through and redoing the carbs and new lines etc, it takes a bunch of spinning over, coughing, spitting, rough chugging, and tons to of exhaust smoke for them to settle out and purr. 5-10 minutes of startup whoes. I have another post on this site that lays out my process I go through in reviving an old Doo
- only thing you may have wasted money on was replacing the rav valves. Why?
If it still doesn't run, you may have to get into electrical troubleshooting - ignition coil, spark strength, stator leads ohm testing, stator timing. On timing, in all the above did at any time the rotary valve cover come off, any chance the RV timing has been disturbed/offset?
Ps; a backfire is usually a flooded engine. If that is the case Kick it over half throttle open, NO choke, and keep spinning her till she fires up and clears out.
Sounds like it
In your first post you said you replaced your battery. What battery did you purchase? After all the cranking you've done trying to get it to start, have you put the battery back on the charger?
The rotary valve is simple but you will need a degree wheel to check and make sure it is right. If you search "seadoo manuals" on Google, you can find the manual for your year and it will say how to do everything.
Your idle out of water needs to be up near 3000 rpms. There is an adjustment screw on the MAG Cylinder carb (right carb closer to the gas tank).
I might have missed it but what do your spark plugs look like? What spark plugs are you using? What is the gap of the spark plugs?
Spark plug gap should be 0.020-0.024.
Clockwise will increase your idle speed. It sounds like you are turning it counter-clockwise if you're twisting to the left.
Honestly, I'm not sure what you should do. I don't want to tell you to do that in case it causes you to run lean of oil therefore causes engine damage.
Any reason why you went premix?
