97 gtx wont start
gasman1978
i have two problems 1. the motor wont turn over i was out on the water literly an hour ago no prob ski ran ran great got to the ramp loaded it on the trailer opened the drain plugs it had unsually large amount of water. so when i got home i hooked the water to it to see where the water was commin from and thats when the when the problem started ski never turned over again just get one bump like sound.....2nd problem info center wont come on is there a fuse or a plug that may have blown or come loose plz help,,,,, sorry its so long
Problem I had with my 93 sp was the ground cable to the block had loosened. Check there first. Make sure cables are tight on battery. Check voltage at battery. Check positive lead at starter, make sure it's tight. As for fuses, there are a couple in the MPEM box.
thanks for the advice seems the prom with mine was water in the motor removed spark splugs from motor and held start button til water was gone installed plugs and it started right up:cheers::hurray:
