I have acquired a 97 GTX LTD which has a new motor in it. It seems to run fine but top speed is about 42 miles per hour. It comes out of the hole strong and seems to run perfect with the exception of the top speed. I have run along side my ski boat to check the speedometer and it is pretty accurate.
I am getting a low voltage warning flashing which I figured was likely a rectifier problem which may also be contributing to the top speed issue.
I bought a new rectifier but for some reason this ski just doesn't seem to have one.
There is only on control box up front and there is not rectifier anywhere near it.
Its possible this isn't really a 97, anyone have any ideas as to where the rectifier may be and what years didn't have a rectifier?
The ski can run for about a week without me having to recharge the battery, once last year after a really hard landing after a jump the low voltage warning went out but came back on again about an hour later which may also indicate a possible loose connection somewhere.
So if anyone has an idea as to:
1. Where might the rectifier be?
2. If the year is wrong and there isn't one, what else could I check for low voltage issue.
3. Could the voltage issue be a cause for the top speed issue and if not what other things should I be checking for.
Thanks for any help you guys can be.
Randy
Randy
