97_Sea_Doo_GTX
Hello everyone,
Hoping to get some advice on an issue I'm having with my GTX. Took it out last week and it started out running great. After running it a couple of miles it acted like it was starving for fuel and finally died and wouldn't restart. Had to be towed back to the ramp.
First thing I did was check the plugs. They were light gray so it confirmed it was running very lean. Next I checked the compression. 145 on both cylinders. Checked the water separator/filter and it was clean. Disconnected the fuel line at the carb and was able to easily suck gas through with the shutoff (replaced late last year) turned to ON and then RESERVE. Fuel flow stopped as it should when I turned the valve to OFF.
Took the carbs off and took them both apart. I rebuilt them a few months ago with genuine Mikuni kits, needle valves & seats. Everyything was spotless and the screens were completely clean. Checked pop off pressure and it is about 36-37 on each carb. Put the carbs back together and reinstalled them.
Removed the baffle from the fuel tank and there were no problems with it at all. The screen was very clean and both pickup and vent tubes were clean. Blew compressed air through all fuel lines and they were free. They were changed to 1/4" rubber fuel hose right before I got the machine.
I then removed both fuel tank check valves and confirmed they were working as they should. The pressure release check valve only opens with a little pressure applied and the vacuum check valve flows freely toward the tank. I also looked inside the tank through the baffle hole and it looks spotless.
After putting everything together, it fired right up and sounded great on the trailer. This morning I took it out to the lake and it ran pretty good at first. had a little bit of a bog but snapped out of it and ran up to 6500 rpms. It used to run up to 6700 rpms. As I drove it more the top rpms kept on creeping down just like last week until it would only idle and, even then, not very well. Turned the shutoff to reserve which made no difference and I removed the fuel cap which also made no difference. Barely made it back to the ramp.
The new spark plugs are light gray again. Battery voltage was at almost 13 volts when I got back home so it seems like the battery is keeping the voltage up to normal.
Where do I look next? I can't put my finger on what is causing the lean condition after running for a period of time and then acting like it's completely starved for fuel. Any advice will be greatly appreciated. This machine had been running very strong until last week and it seems that I've checked all of the logical areas, at least all that I can think of.
Sorry for the long winded post but I wanted to make sure I covered everything I've done to try and resolve this issue.
