Strokerridge92
Got the ski out for the year, hit the start button the lights flash once then keep flashing and it turns over but won't get any spark, has new coil, stator, battery, what else can it be?
Coastie,
Doesn't one beep mean that the MPEM cannot read the lanyard?
Maybe the wrong key??? Avatar says both 96 and 97 GTX
If it did lose the program, the only fix is to get it reprogrammed. This can be done with a Candoo Pro which is just under $400. Go to the dealer with the ski and lanyard and most charge right around $70 or so. Or, send the MPEM and the lanyard to [MENTION=41828]Minnetonka4me[/MENTION] and he will charge you $30 (I believe).It's the only lanyard that came with the 97, the other one doesn't have one at all. Any way to fix it or anything?
[MENTION=31048]LouDoo[/MENTION], where is the MPEM mounted in this ski.Okay, and I'm pretty new to ripping into these, which box is the mpem. And is it two semi quiet beeps that I'm looking for?
