CRei
Hi what are the systems of worn crank seals? Hers the scenario, on trailer sometimes hard start sometimes one tap of button fires right up, sometimes excessive smoke sometimes normal smoke and sounds powerful, cranks slowly then acts hydro locked, remove plugs cranks good. Install plugs either locks or cranks and fires up. Carbs were done , then changed completely to a known good set, fuel lines ,selector and complete filter housing. It will run like perfect at times powerful revs up great, other it will fall flat on its face. Wow sorry so much info. Thanks
