B bagger New Member Jun 25, 2014 #1 is it possible to run mixed gas on a 717 having a rotary valve gas does not mix with oil any help would be great thanx
AdamXP800 Well-Known Member Jun 26, 2014 #2 Yes you can premix. But you need to keep the oil tank or loop the lines to keep oil to the rv. You will need to install a block off kit. However, the OEM oil pump is very reliable if it is maintained Last edited by a moderator: Jun 26, 2014
