If you want to go to a pre-mix system, that's fine. Remove the pump, and cap of the hoses.
The rotary valve gets it's lube via the 2 other hoses. So, if you go to pre-mix, you still leave the oil tank in the hull, with about half a gallon of oil in it... and leave the 2 rotary valve hoses hooked up.
