So I cleaned my dual carbs on the 97 challenger. While putting it back on, I was testing the throttle lever. If you are leaning over from the seats, the throttle adjustment closest to you, I have set so it just barely closes the butterflies all the way with no throttle. My problem is, when I am at full throttle, they aren't really at full throttle, I can push them by hand another 1/2 inch or so. I tried adjusting the back of the boat carb jam nut both directions, but that doesn't fix the problem. Is there another adjustment I am missing? Or do I have to adjust it at the throttle lever itself. One more thing, from idle to about 1/6 throttle, it doesn't move the butterfly at all, is there a way to change that? Thanks for any advice.
