Hello everyone,
I am new to the forum, and I thank any help I can get.
I have a 97 challenger 1800 with twin 110's. The port side engine runs and starts relatively easy but has a miss in it when it builds rpm. After a couple of minutes of running it just flat out dies. It will not restart until I remove the DESS key and stick it back on, then i fires right up and runs fine until it comes under load again, at which point it begins to miss about once every 10 seconds.
So far I have changed spark plugs and changed fuel filter. The plug wires are good and on the plugs well. Next I was going to swap ignition coils, and the the start/stop switch. I fear that it could be the MPEM. Does any one know what is involved in changing that out?
Thank in advance.
Thank in advance.
