bflowers1971
Hey y'all! I am new to boating and 2 stroke stuff so please be gentle... I picked up a used Challenger 1800 (1997) the other day and, as you can imagine, it has some issues. I've downloaded the service manual and been studying it to iron everything out. I'd like to throw my concerns out there to get any input and advice. First off, thanks in advance!
Here goes: the port motor is claimed by the PO to be new (and it looks it) but it intermittently turns over like the starter is acting up. Once she starts, it'll only rev to 3500 rpm. I'm thinking it's a fuel issue and gonna look at the carbs. The starboard motor barely starts and has the same starter issue as the other one. The PO told me he thinks the timing needs to be set since he set it and it could be off 10 or 15 degrees (sounds like he "eyeballed it"). Since I'm getting into the timing, I'm planning on going through those carbs as well. Of course I'll be including new plugs and filters as well. I'm kinda scared of running it for more that a few seconds on the trailer without water and trying to figure out how to use the hose correctly. It sounds like I have to pinch off the hose to the transom drain so as not to let the hose water bypass the engine. I know that's a lot and trust me when I say there's more (mostly little cosmetic things). I hope I'm going in the right direction. thanks again if you read this whole post!
