Richieskis
Hello everyone and thanks for reading my post and your help in advance, ok my 96 XP 800 has a new problem that has stumped me, ok, it is now acting like it has a bad miss, as you try to accelerate, motor seems to be cutting in and out. Ok, history, it has about 10 hours on a new top end, compression is 150 psi, and was running great until the last trip out, when it was put in the water with the plug not in, by the time it was noticed about 10 to 15 min, the water was up about ¼ of the bottom of the motor, the rear back electrical box had about an 1” of water in it, got all the water out asap, dried out everything but now it has the bad miss as you try to accelerate, spark plugs have been replaced sense water in haul, compression re-checked still at 150 psi, last summer fuel lines replaced and fuel selector clean. carburetor cleaned, rave valves cleaned and re-sized for new top end, Help, I am thinking something that got wet and damaged but not sure, your help ? please give me inpu
