I have a weird intermittent problem with a 1996 XP. Most of the time the ski is freaking awesome, pulls hard and will peg the speedo at 60mph but then it will feel like it drops a cylinder and just runs on one. I believe the problem is electrical because if I can get to someplace where I can mess with it while it is doing it I can get it to start with the rear plug wire on either cylinder but neither cylinder will run with the front wire. I believe the ignition system is the same all the way up to the coil so the last time out I replaced the coil with one that I had from a GSX Limited that is apart right now. The ski initially had the same problem but about 2 minutes into the day it cleared up and I ran 3/4 of a tank of gas through the ski and it ran flawlessly and then, just like that it dropped a cylinder and it didn't come back all the way back to the ramp. I have another coil on order and will try another one to confirm but other than the coil I cannot think of anything in the ignition system that will affect just 1 cylinder.
Now here's another weird thing that makes me think it might be carb related. When it does have the problem, I can turn it off and sit for about 30 seconds and then when I crank it up it will hit on both cylinders for about 10-15 seconds and then drop the cylinder again. That makes me think that one carb is running out of gas and when I sit there it is somehow filling with gas but cannot keep full under load. Also, even when it is having the problem it idles fine and will run okay up to about 1/8 throttle which makes me think its a main jet problem of some sort.. So I pulled the carbs thinking there was something floating around in the carbs that was occasionally blocking a jet but they were clean as a whistle.
Now I'm starting to think the rev limiter is kicking in way early and causing the problem but I don't know of a way to test that other than replacing the computer.
So I'm stumped. The fact that either cylinder will run on the same plug wire and neither will run on the other make me think electrical but replacing the coil didn't help. I've replace plugs and it doesn't make a difference either. If it is electrical, why does it idle fine?
Other than just throwing money at it does anyone have any ideas?
