rotaxrule1
Well, trying to wake up all my machines for the spring to get em ready. The GSX with the new engine seems to be behaving so far. The GTX fired right up. XP? eh, won't start. Killed 4 batteries (switch out, charge, rinse and repeat).
I keep pulling the plugs and it appears to keep getting flooded. I might have sprayed too much bombarier lube down there when winterizing or maybe the carbs were leaking fuel into the case while sitting. not sure. I have tested spark by grounding the plugs to the head and cranking, switched plugs, etc.
Is there any way to get this thing cleaned out enough to get a good fire? It does not seem to spit anything out when cranking with the plugs out. Almost seems like it needs the compression to draw the liquid out of the case. As I have mentioned with previous posts, I really hate to use starting fluid.
I need to pull the carbs at one point anyway I am sure, it still has the gray lines and probably has screwed something up with the carbs.
Thanks for any advice.
:cheers:
Brandon
:cheers:
Brandon
