Rainman001
So been racking my brain on this one, I think it has to do with a bad impeller. Have a 96 SPX that will completely lose power while on the water only. If i run it on a hose, there's no power loss at all. By power loss I mean it will be going full speed, and then just go back to idle, then back to full speed, then back to idle, about 5-10 seconds between bursts.
I recently had a stud on the top of the tuning pipe break which caused the hull to fill with water, but I can't see this causing this issue? I've tried moving electrical wires around simulating it moving on the water and can't replicate the issue.
Anyone have any suggestions where to start?? (Also, checked, there is no sea-week or anything blocking the intake).
Much appreciated!!
Much appreciated!!
