I have a 96 sportster with 718 rotax motor with twin mikuni carbs. Has 135lbs of compression in each cylinder.
Here is the problem i put it in the water after top end rebuild. ran good first two time. 3rd time in the water it would go the suddenly lose power like it was running out of fuel. So i pulled the air cleaner and watched the fuel while i drove. It would go good for 5 seconds then no fuel spray at all.
Do you think its a fuel pump or some thing internally in the carbs? the internal filters are clean.
Thanks for anybody that replies greatly appreciated.
