speedyboyl
I bought a 1996 speedster twin rotax about 4 week ago and for the first three days i had no problem with it, ran out fine. I took it out of the water and when i put it in the next weekend the port engine ran fine for about 5 min then shut off. It would restart but with a bad shimy and backfireing through the rear carb. i have gone throught the shop manual from start to finish, moved the carbs from one engine to the other, took the carbs apart and cleaned them, even took off the rotary valve cover and resealed it. i can't seem to find out what is wrong, i have gotten it working fine inso that it no longer backfires at idle but as soon as you give it some gas it starts to backfire again. the other engine runs fine on both sets of carbs and the plugs are giving the proper spark. If anyone else has had this problem or somethign similar please let me know before i have to take it to a professional, and spend a ton of money, thanks
