uraceulose
Any ideas?
I’ve been working on replacing all fuel lines, fuel filters, rebuilt all 4 carbs, fixed gas gauge, tightened throttle cables, replaced both fuel control valves, replaced both oil pumps to get injection system working, replaced bilge pump, replaced both wear rings and changed pump oil. Still in the process of replacing both carbon ring kits...
Got the lights working by replacing the fuse and changed the rear compartment struts so it stays open.
That is about all I’ve done that I can think of.
I also cleaned out both keys with baking soda because it would intermittently not turn on or turn over when using the key
Now with the pumps off, driveshafts removed as well as the carbon rings/bellows pulled off, neither engine will turn over when I push the start buttons?
Gauges light up, bilge, fan and lights work but she won’t crank.
Any suggestions or things to check for would be much appreciated.
I’ll go double check fuses but if you guys have any other advice I’ll go try that too.
Thanks so much
Donnie
Thanks so much
Donnie
