Phuck_boi
I’ve spent hours browsing this forum and people do not post conclusions of how they fixed this issue. Boat intermittently hits 6800 rpm and now I cannot get it past 5500. It will get on plane and hit over 30mph but when it runs like it’s supposed to it’s closer to 6800 at 45mph. I’ve rebuilt the pump, overhauled the fuel system, rebuilt raves with slotted valves and new bellows/o-rings, compression is 145mag/155pto (not sure if this is an issue), flushed oil system it had clear oil in it, not sure wtf it was, now running appropriate Seadoo oil and cleaned the power valves, set oil flow and has a fairly new oil injector, rebuilt carbs with mikuni parts, put new o-ring in fuel filter. Could this be a fuel pressure issue? I’ll choke it when it’s flattened out and it immediately kills it, plugs appear to be burning correctly. Stumped, my friend thinks it could have been an issue caused by the improper oil being ran through it, but even when it was burning the undyed oil it achieved top speed. Could it be an MPEM issue, idk, I’m a newer Seadoo owner and learning on the fly. Any help would be greatly appreciated and if I do come to a conclusion I will post the fix.
