'96 seadoo XP 787 locked up??
I figured it out, however...
You should be getting spark at this point.
So I found out that when I replaced the stator, I also replaced this black trigger thing thy connects to the stator. Idk the exact name. But anyways, I ended up putting the trigger backwards which would not allow for the spark to spark. Hope that makes sense. I fixed it and it started right up. BUT, now I put it in the water and it starts to leak water bad in two spots. Idk where exactly but I know it is coming in from where the shaft enters the ski right behind the motor where the black cool things are to cover the shaft. Water is also flowing in from what looks like the pump. Is it possible I didn't seal it correctly? Idk how to stop either leak at this point. HELP PLEASE!!!!
And yes I had the plug in the back of the ski in...
inspect the vts boot for tips..
You posted that your compression is 110?? Thats very low man, should be at 150 mark.
