96 GTX weak spark on one cylinder
easyg
I have a 96 GTX which is low on power. Both plugs are sparking but one is very weak. I swapped out the plugs and the weak spark stays with the same wire.... I am thinking a bad coil pack???? Any other ideas?
Thank you!!
G
Try removing the plug boots and cutting the plug wire back about 1/4 inch and replacing the boot. That way you will be connected to fresh carbon.
good luck
