Listen to Miki, Group K knows what they are doing, and a resleeve still needs clearance checked on the piston going into it, if you never rebuilt a 785 get a service manual, example normal engines you put Loctite on the head bolt threads and grease the bolt shoulder base (for torque readings), not the 785, synthetic grease on threads (bolt is stainless and hole is cast iron/aluminum, dissimilar metals and will corrode) and blue Loctite on the shoulder. Here's 1 for you, all the exhaust flange bolts get synthetic grease except 1, which 1 and what does it get instead, and why? Tic Toc...... {;o). Lee
