I have been working on this for a few days and im stumped. It is a 96 GTX with the 787 and dual carbs. It wont run or start because im not getting fuel. I replaced all the gray fuel lines and then cleaned the carbs. That didn't work so i cleaned the carbs again. Im not getting fuel to the carbs if i can it will run but its not pumping fuel from the tank. I ordered carb rebuild kits and installed them today. New diaphragms and everything still not pumping fuel to the carbs. I replaced the line from the crank case to the carbs that didnt help. Im not 100% sure how the fuel flows as far as which is the return or the feed line to the carbs. I have cleaned the fuel filter up front also but i cant get fuel to my carbs at all. Any suggestions???
Thanks
Thanks
