sschnei
Appreciate the feedback recieved from this forum...thank you.
So I've gone trhough the '95 and "96 GTX purchased recently. Replaced the gas lines, oil lines, pump oil, and spark plugs on both. Installed fresh batteries and compression check out good at 155 psi. The '95 is done and ready to go.
The '96 got a new wear ring, but still needs carbs work...it's bogging. Could just be the internal filters, but I went ahead and purchased a couple of Mikuni kits. I'm a little reluctant. My concern is getting the carbs set right afterwards...getting the mixture set right so I don't create bigger problems. Are they hard to set and get the mixture right?
Appreciate any input you may have.
Thanks
Thanks
