96 GTI bogging issue ???
ape1972
Hello Everybody,
I have a question for you all and I will try to be as detailed and descriptive as possible!
Last summer I took the Doo's out for a camp trip and had an issue regarding bogging. It ran okay for a while but the more I rode it the more temperamental it became. It ran ok with one person but with two or more it started bogging down to a stall. Then would need to feather the throttle just to start it again. Once I started it the process would repeat itself. I also noticed that the head was very warm to hot. No buzz due to overheating though. Any input will be greatly appreciated.
Check compression first. If compression is 150 it’s good . 120 and below time to rebuild. If compression is good time to rebuild the carbs. Are your fuel lines gray ? Also check to make sure your stator is charging. Run it on the hose and check battery with volt meter. It should be between 13-14.5 I believe.
You have probably killed the engine. NEVER continue to ride a 2-stoke ski if it's not running properly. plugged carbs can kill an engine.
But as above... start with compression.
One other quick question!
I checked the compression two years ago and it was 150psi in each pistons. I use my Jetskis two maybe three times a year max. Could my compression get that low in that short of time with that little use?
Thanks again
