Spimothy Leary
ok dropped the engine back in my 96 challenger project boat this afternoon.
Dess beeps twice, when you engage the starter button, it turns over for about 3 seconds, then stops, i can't get it to engage for more than 3 seconds or so.
so, started the process of elimination, and i'm not liking whats "left" on the list, maybe there's something I overlooked.
ran power to the starter itself, turns over and stay's on just fine, so its not the starter
replaced dess post, just fine & dandy
shorted the little switch under the throttle/reverse, no change (reverse appears stuck, i'm going to replace the cable)
replaced solenoid inside ebox... nothing different,
checked the hots/ground's all seem just fine, fuses too.
i'm kind of down to a possible bad MPEM... unless 'm overlooking something obvious.
since I really don't know if, or how it was running at the time of its demise with the previous owner, I really can only do the obvious, diagnose, check and recheck, but the engine was shot, and there was an exhaust leak, so it seems like it would be weird for it to have MPEM issue AND blow the engine at the same time, but well, u never know. My best guess is that the exhaust leak caused the motor to get water in it, he left it sit for just long enough for it to completely rust up, the only thing I salvaged from the engine was the cases.
so.. any thoughts/suggestions to help turn around my day ?
