Mgiffune
First post of the 2013 season, and looking for some help from the experts! My 95 xp is having a hard time starting. I started having the problem last year, but it’s time to do something about it. It runs fine once it’s started, just seems take a lot of cranking to get it here. This happens both in and out of the water.
Fuel lines were replaced in 2011, fuel selector cleaned, clear fuel filter installed, battery is new, and the carb was rebuilt by a mechanic friend last year. Now, one of the bolts holding the carb onto the manifold was seized up when I tried to remove it, and I had to beat the hell out of the thing to get the bolt out of the carb, including heat, impact, etc. I was about to give up and replace I when I found someone who was able to bore the bolt out. I’m just wondering if maybe some damage wasn’t done when trying to remove the bolt?
I rebuilt my 97spx 800 carb last year, and it’s running great. So, I’m confident I can rebuild the 720 myself again if necessary.
To get to my question, is it worth rebuilding this carb again? How easily is a carb ‘damaged’ trying to remove the seized bolt? Is a primer kit the way to go? Any other suggestions?
