I have a 99 xp just installed new motor, started ran for about 5 mins ok, then restarted ran good then would surge up to 35000 with out giving it gas, idle screw is backed all the way off.Restarted it idled ok for 1 min the started going up in rpm to 7000 tried to hit stop botton didnt work pull lynard still ran, ???????If you hit the gas it brings it back down to about 3500,then goes back up in rpm. Not sure if its a cab problem or block sealing issue. Stop button and lynard work ..just dont seem to work when it goes wide open so looks ike i have 2 issues..........
