SabrToothSqrl
So as many of you know my 02 XP with new engine, reeds, and carbs is topping out at 6k.
I get to 6k at approx 80% throttle. The last 10-20% throttle has NO affect on the RPM. it will redline without load.
There is no crazy pull like my 02 GTX has.
So I pulled the carbs, they came in a WSM box and said 1998 GTX LTD in them. They are seadoo 951 OEMs
I had to swap the choke cable pull to use them in my XP. I also tonight changed the throttle pull plate.
I think I found something. I never messed with the carbs on my own before. But I figure it's time to learn.
New carbs:
Pilot: 82.5
Main: 165
2002 carbs
Pilot: 75
Main: 157.5
The interwebs says I should have
Pilot: 75
Main: 162.5
What do I do?! The whoe ski is stock but the prop, a concord 15/20.
The springs on both are shiny silver and the Needle is 2.0 in the 2002, I will have to check the 'newer' ones.
Could this be my missing RPM? The engine seems to foul plugs.
I run stock of 1.5 low and 0 high.
Thanks Guys, figure I'd give this a shot before scrapping it.
My 02 GTX is stock, 60 hrs, 6,810 WOT and 63-65 MPH on GPS. All stock but the Solas 15/20.
So why won't my XP spin the damn thing at 6800?! (7k stock prop).
This ski used to have an engine with a shaved head and possibly other parts. I've returned everything I know of to stock. So could the PO have messed with the original carbs? Is that why the jetting is off?
New carbs:
Pilot: 82.5
Main: 165
2002 carbs
Pilot: 75
Main: 157.5
Pilot: 75
Main: 162.5
