garrettb
I'm starting a new thread with more specific information on the issues with my 2001 GTX DI. It cranks but will not start. Here is what I know:
-good engine compression
-working air pressure regulator
-working fuel pressure regulator
-good spark
-good spark plugs
-good air compressor
-no blown fuses
-fully charged battery
For some reason, no fuel is being injected into the cylinders. I took both sets of injectors out. They click really well and seem to work as intended when connected straight to 12V.
I rented a fuel pressure tester. Inserting the key immediately yields 27 PSI. When cranking, I am at around 75 or so, the needle jumps around quite a bit. That testing was done with a "T" inserted in place of the fuel filter. With the gauge dead headed on the fuel supply line, inserting the key (no cranking) yields over 100 PSI- it maxed out the gauge.
I have a "maint" light on my dash that doesn't clear, but before I spend some serious dough at the dealer, what in the would could prevent the fuel and direct injectors from energizing? This is crazy, and I am really frustrated with this thing. I am almost upset it wasn't the fuel pump, because that should have been a straightforward fix.
-good spark
-good spark plugs
-no blown fuses
