DirtyDan5150
I’ve just did a full rebuild on my 2002 951 DI LRV.
New OEM fuel pump
New crank
New pistons
New air compressor
Fuel pressure is ok. (25 psi with lanyard, 100 when it does fire for a couple seconds)
I think my gauge reads a tad low.
Compression is 130 in both holes.
Both the fuel injectors and air injectors have been OHM tested and cycled with 12 volts to check functionality.
Ski will occasionally start and run but very rough.
I’m not getting any maintenance light.
But the strange thing is that my fuel pressure bleeds off when the raves cycle after a failed start.
I think this might have something to do with a connection that is misrouted somewhere.
Why would the raves cycling bleed off my fuel pressure?????
Is this normal?
I think the fuel pressure should hold around 107 for a little while even after the engine is turned off.
Anyone offer any advice????
It would be much appreciated!!!!
Thanks in advance……
New OEM fuel pump
New crank
New pistons
New air compressor
Is this normal?
Thanks in advance……
