So about a month ago I had my XP out on the water and it was running fine. I friend hopped on and then never came back. I ended up swimming out to him and pull him in. He said the engine had died on him around 6 times. Each time it took longer to start until finally it wouldn't anymore. I figured he flooded it, cut the gas, and tried to start it. it would try to start but just didn't seem like there was enough left in the battery. Thinking the battery was dead we loaded it up and took it home. Where I promptly pulled the battery out and put it on the charger.
it sat for a while and I didn't get around to testing it until the following weekend. When I did, with a full battery I got the same results. engine starts to turn, but just kind of gives up. it makes a sound almost like there is an intermittent connection in the wiring.
Here is a link to a short clip of what it is doing: Link.
Now I am pretty sure there is an electrical problem happening so I get to work
1st: Tried a different battery - Same result
2nd: replaced battery cables and starter cable - Same result
3rd: Since they are cheap and readily available I just went ahead and replaced the solenoid - Same result
4th: Found a brand new starter for a fairly low price so I just went ahead and swapped it on - Same result
In addition to all of this I have:
-Jumped the solenoid - Starter and Crank spin freely
-Tested the start/stop switch for continuity - It passed
-Tested safety lanyard switch for continuity - It passed
-Checked all fuses including the ones to my bilge pump and TrimFix power wire - All looked fresh as the day they were put in
-At this point, I was running out of ideas, so I checked all the connections in the box - None were loose
Just hoping for some insight. Pretty much everything in this ski is brand new (the starter was one of the last things). So new, I still haven't even finished the motor's break-in period. Hoping to get this thing on the water before the season is up!
