vallentinerocks
95 XP all stock, no mods. Rebuilt both carbs, changed all the original fuel lines, Compression on both sides 125PSI, low speed at 1.5 turns, high speed at 0. DOES have leaking crank and/or rotary valve seal leaks since oil comes out of exhaust periodically when have been able to throttle up. Had been sitting for over 6 months unwinterized and uncovered by the last owner. been in my garage for 4 months. I have yet to take it out to water.
SO... I can get the ski to fire up and idle without starting fluid. First start = high idle and can get response when throttling up and ill shut down in a few seconds. (its in my garage). Second start = starts up and idles lower, but when throttling, has little or no response and will die. Inspect plugs, Mag side plug seems a lot wetter then PTO side.
Recently on one starting attempt, it fired up, revved up high RPMs on its own, and when i pulled Lanyard to kill, it didnt shut down and RPMs were still high. Motor shut down when i throttled up before i could reach for the choke lever.
So basically now, the ski starts almost everytime and randomly idles right or idles high, but definitely issues since im getting weak or no response out of the throttle and will die. U think its running RICH or running LEAN right now??? Im Leaning on the LEAN side. Please Help. Im not all that knowledgable on carbs and tuning them.
