Chrisitsmee
Hello and my question is this , after last winter i went to start the ski and it acted like it was hydraulic locked but finally started and oil just poured out the exhaust , i mean liquid oil and a lot of it , i shut it down right away and restarted it and it did this again , i went looking for info and someone said i had a middle crank seal go bad
it sat all last summer and just now i pulled the motor thinking it would need work and found liquid oil in the bottom of the crankcase its like full of oil
it has me wondering is there some kind of 1 way check valve on the oil line that failed and let the oil drain into the motor from the oil tank since its higher
or would that seal being bad allow the motor to suck that much oil out of the tank
sorry for my lack of knowledge about the oil tank and lines , im just trying to figure out if i could just ditch the oil tank and run mix in the gas and save me a huge repair bill
any suggestions if i need motor work who to have do it?
im thinking about this place http://www.fullboreonline.com/rebuilt_seadoo_engine.htm
any and all info is appreaciated so i can make a informed decision
thanks again for your time and patience
