also, if im understanding you, i could run the 657x mpem for now, and would be slightly down on power? is it true the 657x has a more aggressive spark curve? possibly giving better midrange? sorry for all the ??? this is my first ski project in a while
What is the pn on the back of the mpem?
I'm no expert but I read a post where the 657X is comparable to the 717.
Its the 657 that is not.
Heres is a quote from bills86e
"In 1994 the XP had a 657X motor with a 278000071 mpem.
Kindly look in your electrical grey box for the big module with about 13 wires or
so, and look on the back for the part no.
In 1995 the XP went to 717 (and 787) 717XP engine with a 278000423 mpem,
that also that mpem was used on the GTX 657X engine. Same flywheels &
stators, so that kind of leaves us to conclude the two mpems timing curve
ROM is the same on the 717 engines as 657X. Carb Jetting IS different.
Suggest you open mag cover, pull flywheel and see if Stator timing marks
at 9:30 o'clock are aligned and woodruff alignment key is intact, clean by
vaccuming, and close back up. I agree with SeadooSnipe that the Rotary Valve
needs re-checked for its timing position, and that the 717 needs a 159* valve
properly positioned on the RV gear useing a degree wheel and the mag cylinder
at TDC.
From link
http://www.seadooforum.com/archive/index.php/t-24354.html
