scubastevehere
They was not used for a few years. They were hesitating on acceleration and running horrible. Rebuilt the carbs per instructions found here, replaced gray hoses, cleaned fuel tank. They run ok . When running on water hose they have oil in the exhaust. Reading threads has told me it's probably the rotary valve shaft and seal. But some threads say the crank seals too. A local repair guy also said RVS and crank seals. Is it possible it's only the rotary valve shaft and seal? One thread said you can see it weeping when you get to it. Also can you get to it while in the ski? I really don't wanna take out the engine unless it's necessary. If I can get by with just the RVS, and the crank seals leak a smidge, I am ok with that. And are there any detailed instructions anywhere for doing so. I have the seloc manual, but the instructions are not seamless and would jump from chapter to chapter. Thanks for any and all input.
