krazybob738
Hey everyone i am looking for some help /advise. I just picked up this 1995 speedster with
twin 657 engines. Ok so here we go this is gonna be kinda long!
I have a list of upgrades i wanna do to the boat like switching to single big batt for the engines
but have heard this is bad for the mpem is this true?
Also i would like to add a second batt for a stereo and speakers and maybe an amp not sure yet.
I will be putting in a batt switch to manage the batts.
I also wanna add some led lights to the boat. (inside and outside and engine compartment)
I also wanna add some hydro turf for sure.
I also wanna add at some point a bimini top.
I have a friend who does decals so at some point i will be replacing my decals.
Any other suggestions are more than welcome!
Ok for the short list of things to fix are.
I have a loose throtle cable if i let go of the stick it just falls back to idle.
I need to add new wear rings and will prob replace the props i have massive cavitation issues.
what do you think of using sbt props? How hard is this job i am kinda scared to tacle it?
Also my boat is taking on water for a hole on the back of the boat what is this hole for?
(pic below) the only reason i suspect this is i decided to put water inside the boat add
see where it leaks out from and this is the place i had the water level just above the carbon
seals and nothing. I i also thought maybe water was coming in from the bilge but still not a
100% sure yet. Let me just add the water never goes higher then the bilge pump is this normal?
I am gonna put in new upholstrey this winter.
I have no speedo unit on the back of the boat the po removed it but the gauge is still there so i
will be looking for a new one of those.
I also need to get my fuel baffle fixed i have no fuel reading.
