rolando14
so got everything in working order to start both engines in the drive way but neither starters seem to have enough oomph to turn things over. I'm wondering if it is a problem with the jet pump?
the most I could get the port engine flywheel to turn was 1 revolution and about 3/4 on the star side.. I pumped the fittings with grease also.
Any advice for an amateur? I'm prepared to remove jet pumps but was hoping to get some advice first..
it seemingly isn't the engines because after removing spark plugs, the shaft didn't spin any better.
help is much appreciated
