95 speedster deck drain tube
aeboi863
well the drain hose by my fuel cutoff switch on my 95 speedster isn't draining out unless i put force water thru it 1st. any suggestions? once i fill the deck back up with water it wont flow again till i put more forced water back thru it like i said before.
Check the scupper valve on the back of the boat. It's probably plugged up with leaf littler.
is that the black rubber 1 the water flows perfectly from the other drain which comes out @ the same spot. the flap is partially open all the time it and its free and clear
OK... great. Then you don't have any problems. :rolleyes: Glad we could help. :cheers:
OK... sarcasm aside, it's real simple. There is a drain fitting by your foot, a hose, and that black rubber valve in the back. It's plugged up if it's not draining. Take the valve off the back (4 screws) and blow it out with air, or your garden hose.
well i tried the garden hose today and got alot of water on the deck but the drain is only flowing once the water is forced thru then the force going back out makes it all flow thru im taking it out on the water tomorrow 2 see if its gonna work properly then. wis me luck LOL
If you open the engine compartmen... you will see the white plastic hose. You can take it off, and replace it if needed.
