IBGMann2
Hello everyone,
I'm new to boating and have a question about my boat. I recently bought a 95 seadoo speedster. I've had it out 5 times with no problems. Last weekend while on the river I idled out of a no wake zone and cranked on the throttle and both engines stayed at 3000 Rpm. It was almost like a rev limiter sort of thing. I quickly started to go back to the dock when the alarm sounded. I killed both engines, opened the engine compartment and found that the right engine was over heated. I got the boat back on the trailer and found plastic stuck on the jet pump clogging the water inlet. Cleared both jet pumps out and put the boat back in the water. Still both engines will not got over 3000 Rpm, no alarm just will not go over 3000 Rpm. I did a compression check on all cylinders all of them have 125lbs of compression. I am in the process of putting new wear rings in and new plugs. Any other ideas of why this may happen? Is there a fail safe on this thing that causes it to do this. Anyone that can help me would be great. Thanks.
