Underwater78
Hello again, the seadoo just doesnt want to start, i can hear my starter spinning but barely makes the drive shaft move, sometimes just kicks for couple seconds and nothing, sound like is not connection between them. And i dont have spark either, put new spark plugs and already did the cutting on the cables and check for the ground on the ignition coil, unplug blk/red wires from mpem, full charge new battery with new cables, im 90% sure the my ignition coil give up, did all the testing and nothing, before i get a new one can this be the problem for my starter not working right with the drive shaft or is something else besides that, i have compression when i pull out the plugs but not able to move the shaft just 1 inch, any help before give up and call the technician. Thanks.
