95 GTX pump shaft bearing stops from cranking
Tiki Paul
i've been trying to get my 2nd 1995 GTX 657x started for the last couple of weeks. i changed the starter solenoid and starter and battery but the solenoid just clicks.
After reading another post it was suggested that the pump was stuck . When turning the motor over by hand I noticed that the bearing was turning with the shaft and sleeve and not allowing the shaft to turn freely. This is the bearing between the PTO and pump shaft.
Do I have to pull the pump as the manual suggests or is there another way ??
